floating point grass rasters and mapserver
Paolo Cavallini
cavallini at FAUNALIA.IT
Tue Oct 11 03:33:16 EDT 2005
This is a known limitation for grass rasters. Not much to do, unless someone
will write the relevant code for gdal.
pc
At 09:18, martedì 11 ottobre 2005, Andrea Antonello has probably written:
> Hi folks,
> I trying to visualize grass rasters with mapserver.
> What I get are nice maps, but those that are floating point and numbers >
> 255 are visualized in one single color, usually yellow, which probably only
> means that the image is rendered at low resolution level.
> I read the documentation about rasters more than once, but I seem to miss a
> point.
> I use png24.
> If I normalize the map (i.e. map*maxvalue/255), it shows up correctly, but
> I don't want to double the maps and also I want to see changes on the grass
> location.
> Any hint is appreciated.
> Best regards,
> Andrea
Paolo Cavallini
cavallini at faunalia.it cavallini at jabber.org www.faunalia.it
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
