floating point grass rasters and mapserver
Andrea Antonello
andrea.antonello at GMAIL.COM
Tue Oct 11 03:53:07 EDT 2005
Thanks Paolo,
> This is a known limitation for grass rasters. Not much to do, unless
> someone will write the relevant code for gdal.
It's long time now from my last serious C effort.
I suppose this would mean to add a part in the grass code dealing with gdal
(the old libgrass?).
Has anyone a clear idea about what exactly should be done? This would probably
give me an idea whether to try or not :)
Thanks,
Andrea
> pc
> At 09:18, martedì 11 ottobre 2005, Andrea Antonello has probably written:
> > Hi folks,
> > I trying to visualize grass rasters with mapserver.
> > What I get are nice maps, but those that are floating point and numbers >
> > 255 are visualized in one single color, usually yellow, which probably
> > only means that the image is rendered at low resolution level.
> > I read the documentation about rasters more than once, but I seem to miss
> > a point.
> > I use png24.
> > If I normalize the map (i.e. map*maxvalue/255), it shows up correctly,
> > but I don't want to double the maps and also I want to see changes on the
> > grass location.
> > Any hint is appreciated.
> > Best regards,
> > Andrea
____________________________________________________________________________
HydroloGIS - Environmental Open Source Solutions
www.hydrologis.com
Andrea Antonello
Environmental Engineer
mobile: +393288497722
"Let it be as much a great honour to take as to give learning,
if you want to be called wise."
Skuggsja' - The King's mirror - 1240 Reykjavik
