Problem trying to serve large .tif dataset
    Shawn Wallbridge
    shawn at SYNACK-HOSTING.COM
    Thu Oct 13 17:39:45 PDT 2005
On 13-Oct-05, at 5:58 PM, Glen Thompson wrote:
> Hi,
> I am having difficulties with mapserver 4.6 generating output with a
> large .tif dataset.  I'm attempting to setup a large dataset to be
> served
> up via WMS.
> I have a .tif dataset of approximately 2000 .tif files totalling around
> 160k pixels by 375k pixels.  Each tif image is 5000 x 5000 pixels.
> <snip>
> When I request the entire bbox for the dataset, the mapserver.exe
> process
> runs for about 8 minutes and then seems to crash or error out or
> something.  I don't know nor can't find any logfiles to see what is
> happening.
> Has anyone had any success dealing with datasets of this size?  If so,
> how
> have you implemented them?
> Any help/advise would be greatly appreciated.
> Thank you,
> Glen Thompson
Any chance you are hitting 2GB of memory and then it's crashing? From
the sounds of it you are using Windows, and in Windows 2000 a single
process can't access more than 2GB of memory. For anything higher than
2GB, you either need Win2K AS  or WinXP with the /3GB memory tunning.
But with each, you need to run a small binary called (IIRC)
imagecfg.exe against the executable file that is being run. That will
enable what's called '3GB memory tuning'. Their is a knowledge base
article about Windows and Memory...
http://www.microsoft.com/whdc/system/platform/server/PAE/PAEmem.mspx
shawn
More information about the MapServer-users
