IIS5
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Tue Apr 4 14:39:55 EDT 2006
Are all the dll's on which the Mapscript dll depends (use a tool like
dependency walker) in the path?
As an alternative check for the dependencies, put mapserv.exe in the php
extension dir and run it in a DOS prompt using mapserv.exe -v.
Best regards,
Bart
Keiler wrote:
>Hy community
>I am normally working on Apache and the mapserver is running well, but no i
>want to run my mapscript application on our public server, which is running
>with IIS 5.0. After configuration of all necessary files. I get the warning
>message:
>Unknown(): Unable to load dynamic library './php_mapscript_48.dll' - The
>specified procedure could not be found.
>The file ./php_mapscript_48.dll is in the php folder and also in the
>extension folder and i set the extension_dir = "./" .
>Maybe someone can help me with this problem.
>Thanks
>View this message in context: http://www.nabble.com/IIS5-t1394579.html#a3749628
>Sent from the Mapserver - User forum at Nabble.com.
OSGIS, Open Source GIS
http://www.osgis.nl
