Optimizing PostGIS.
Luca Manganelli
luca76 at GMAIL.COM
Wed Apr 12 05:45:48 EDT 2006
I'm trying to optimizie a postgis table.
I did "shp2pgsql" command to convert a large shapefile (17 MB, over
5000 features) then I imported it into postgres 8.1.
I created spatial index and I did VACUUM ANALYZE on that table.
I followed the steps in "Performance tips" on Postgis Documentation at
http://postgis.refractions.net/docs/ch05.html (expecially in 5.2 and
5.3).
BUT, in my mapserver the shapefile drawn at max extent is somewhat
50%-100% faster
than Postgis. That performance gain reduces to a 10%-30% in lower scales.
If I do a point query on Postgis table, it is not much faster (but the
performances are often equals!!)...
Any idea?
"Work only as many hours as you can be productive and only as many hours as
you can sustain." - Kent Beck, in "Extreme Programming Explained"
http://www.trapanator.com/blog
