ogr please help
Skalski Artur - askals
Artur.Skalski at ACXIOM.COM
Thu Apr 13 09:22:26 EDT 2006
thaks I'll give it a try... :)
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On Behalf Of Bart van den Eijnden (OSGIS)
Sent: Thursday, April 13, 2006 12:59 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] ogr please help
You can also use the shptree utility which comes with Mapserver. It will
create the same kind of index (qix).
Best regards,
Bart
> I keep trying but no results...
> still can't figure out how to use ogr2ogr correctly to make index or
> spatial index on my shapefile, can someone help me please
> I'm trying to create index with this statement:
> ogr2ogr -f "ESRI Shapefile" streets.shp streets_plyline.shp -sql CREATE
> INDEX index ON streets USING (CITY_STREET)
> but this generates error1..
> can someone point me how such command should look like correctly, how to
> make this index on shp. file
> artur
> The information contained in this communication is confidential, is
> intended only for the use of the recipient named above, and may be
> legally privileged.
> If the reader of this message is not the intended recipient, you are
> hereby notified that any dissemination, distribution or copying of this
> communication is strictly prohibited.
> If you have received this communication in error, please resend this
> communication to the sender and delete the original message or any copy
> of it from your computer system.
> Thank you.
