Java Mapscript - problems loading .map file on windows - same
code fine in linux
James Dracup
jamesdracup at HOTMAIL.COM
Thu Apr 20 07:42:09 EDT 2006
I'm have a fairly annoying issue when trying to load a map file into a java
mapObj object when running in windows XP. I'm using mapserver 4.8.3 as
distributed with ms4w 1.5.1 - i'm also using the mapscript.dll and
mapscript.jar as distributed with that ms4w. My app is a servlet that runs
under tomcat 5.5, with a sun 1.5 jvm. I'm fairly confident my paths etc.
are fine.
The java code really just boils down to one line:
mapObj mapobj = new mapObj(sMapFilename);
The exception is thrown by that statement. And is..
java.lang.UnknownError: No such file or directory
edu.umn.gis.mapscript.mapscriptJNI.new_mapObj(Native Method)
edu.umn.gis.mapscript.mapObj.<init>(mapObj.java:312)
myapp.ModifiedMapObj.<init>(ModifiedMapObj.java:48)
myapp.Test.doGet(Test.java:37)
javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
I'm sure it finds my map file fine, as if you pass a messed up string it
gives a different error (java.io.IOException).
I'm also confident there's nothing wrong with my .map file as the test one
is simple (map file attached below anyway), everything is in the same
directory and it works fine with a cgi wms request on the same windows
machine. And...
(here's the annoying bit)
..it also works fine when I deploy exactly the same compiled code with
exactly the same .map file and shp files on my linux (fedora) box. On that
box it's a slightly different version of mapserver/mapscript (compiled them
myself), tomcat 5 not 5.5 and a sun 1.4 jvm - but still, why does the code
work on that box and not on windows?
If anyone has any ideas at all it would be much appreciated?
Thanks, James
---.map file contents---
# Start of WMS Server map file
MAP
NAME WMS_server
IMAGECOLOR 250 250 250
SIZE 800 600
STATUS ON
PROJECTION
"init=epsg:27700"
END
EXTENT 275000 180000 285000 190000
SYMBOLSET OSMMsymbolsTest.sym
FONTSET fonts.txt
UNITS METERS
WEB
IMAGEPATH "/ms4w/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
END
LAYER
NAME TopographicArea
METADATA
"wms_title" "TopographicArea"
END
TYPE POLYGON
STATUS ON
DATA TopographicArea
PROJECTION
"init=epsg:27700"
END
CLASS
NAME "default"
STYLE
COLOR 255 204 153
OUTLINECOLOR 0 0 0
END
END
END
END # Map File
