Couple Questions: JOIN and OFFSET
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Mon Apr 24 22:55:06 EDT 2006
Paul Dugas wrote:
> Got a couple questions:
> Is it possible to use the JOIN capability to combine shape features from
> a shapefile with classification data in a CSV file? If so, could
> someone provide an example?
The best way to do this is via postgis. I also believe you might be able
to do this in a limited way via GDAL features in Mapserver, but you can
not do it using just mapserver.
> Is there a way to have a line feature drawn with an OFFSET so that it
> appears parallel to the original line? I am working on code to convert
> polylines into parallel polygons to depict traffic data via color. I'm
> wondering how hard it'd be to have something similar built into MS where
> we could define an OFFSET and a WIDTH to get the same effect without
> having to pre-generate the polygons for different scales. I'll be happy
> to share my polyline-to-polygon code once it's working if that'd help.
I think you might be able to do this with the new GEOS buffer function
that has been integrated with the most recent Mapserver release or it
might only be in CVS. The buffer function takes a polyline and turns it
into a sausage based on an offset distance. Search the archives for GEOS
and buffer and you should find more info on it.
I think you will probably want to look at mapscript to glue all of this
together.
-Steve W.
> Paul
