Learning WFS
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Fri Apr 28 11:00:06 EDT 2006
Chip,
do a DescribeFeatureType request on your WFS, maybe the attribute has a
namespace in front of it and you need to use that namespace in the
LABELITEM, so eg ms:STATE. But to be sure, check your
DescribeFeatureType response.
?request=DescribeFeatureType&typename=states&version=1.0.0
Best regards,
Bart
Chip Taylor wrote:
>I am beginning to learn WFS and have had some success in setting up a WFS
>server using MapServer 4.6.1 under IIS6 and then accessing it. However, I
>am not able to get "gml_include_items" to work. Here is my WFS server
>layer:
># WFS States
>LAYER
> NAME "states"
> METADATA
> "wfs_title" "States"
> "gml_include_items" "STATE"
> END
> DATA "US/States/statesp020"
> STATUS ON
> TYPE polygon
> DUMP TRUE
> PROJECTION
> "init=epsg:4326"
> END
> CLASS
> STYLE
> COLOR 0 0 255
> END
> END
>END
>And here is the call from Mapserver as a client:
># getWFS Layer
>LAYER
> NAME "getWFS"
> TYPE POLYGON
> STATUS ON
> CONNECTIONTYPE WFS
> CONNECTION
>"http://mapwfs.com/cgi-bin/mapserv.exe?map=../mapfiles/map_files/wfs_test.ma
>p"
> METADATA
> "wfs_typename" "states"
> "wfs_version" "1.0.0"
> "wfs_request_method" "GET"
> "wfs_connectiontimeout" "60"
> "wfs_maxfeatures" "all"
> "wfs_srs" "epsg:4326"
> END
> PROJECTION
> "init=epsg:4326"
> END
> LABELITEM STATE
> CLASS
> NAME "States"
> STYLE
> COLOR 80 80 250
> OUTLINECOLOR 120 120 120
> END
> LABEL
> COLOR 0 0 0
> OUTLINECOLOR 200 0 0
> SIZE 20
> END
> END
>END
>Here is the error I receive:
>msDrawMap(): Image handling error. Failed to draw layer named 'getWFS'.
>msOGRLayerInitItemInfo(): OGR error. Invalid Field name: STATE
>If I leave the LABELITEM off the layer draws fine (with no layers). The
>shapefile used by the WFS server does have a "STATE" attribute. I have
>tried replacing "STATE" with "all" in the gml_include_items with the same
>result. Looking at the GML produced, thee are no attribute fields included
>there.
>If I access the WFS server directly using mode=map and include the same
>label info in its mapfile, the labels show up fine.
>What am I doing wrong that the attributes are not being sent by the WFS
>server in the GML?
>Chip Taylor
OSGIS, Open Source GIS
http://www.osgis.nl
