how do I get rid of clicking the button and loading it my
html? {Scanned} {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Wed Aug 2 15:59:11 EDT 2006
Hi Albert!
You can pass parameters through the url.
You must pass the name of your map file.
For example:
http://your.server/cgi-bin/mapserv.exe?map=path/to/your/file.map
Zoltan
There aremany parameters you can set through the url, see the cgi
mapserver reference.
On Wed, 2 Aug 2006, Albert Anderson wrote:
> Hi,
> I am using intializing button as a submit button. The html template is using the get method. I would like to know how to get rid of the submit button. Just have the mapserver auto load into the html without clicking the intializing and get the information from the mapserver. Thanks
> Albert
> Manfred Meier <m.meier at SPIEKERMANN.DE> wrote: I don't know your application and so don't know which initialzing button
> you mean. But if there is a button then it is most likely a submit
> button of a form. Look at the source code of the html page in your
> browser and try to find out, to what url the action property in the form
> tag points.
> If there are no other hidden or visible input tags, try to point your
> browser to the url in the action property. If there are input tags, try
> to append the neccessary values to the url.
> I don't know if that works in your case. But its a often used method to
> circumvent the manual filling of forms.
> Manfred
> Albert Anderson schrieb:
> > Hi List,
> > My question is how do I get my page to load auto like without using
> > initialzing button. I dont want to use the button. I just want to page
> > just load. Is there a way around this? I'm using a linux machine with
> > mapsever 4. Could someone help me?
> > Thanks,
> > Albert
> > Do you Yahoo!?
> > Next-gen email? Have it all with the all-new Yahoo! Mail Beta.
> Groups are talking. We´re listening. Check out the handy changes to Yahoo! Groups.
