What does this error message mean?
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Thu Aug 3 16:27:14 EDT 2006
I don't know that it's an update issue, the choice of version was interesting though.
I'm gonna look through the lexer source code to see if there are any clues there and will report back.
Steve
>>> "M.L. Jackson" <mljacks2 at hotmail.com> 8/3/2006 1:51:34 PM >>>
Honestly, I downloaded this version as an update a while back and I remember
it being a pain so I haven't been looking forward to updating again. I
continued this project from someone else and always have to figure out where
all the files are located and what I actually need to download. I guess I
am now forced to update.
The reason I posted the code snippet is that the error only seems to show
when I add this code to my Java bean.
Thanks for your replies.
>From: "Steve Lime" <Steve.Lime at dnr.state.mn.us>
>To: <mljacks2 at hotmail.com>, <mapserver-users at lists.umn.edu>
>Subject: Re: [UMN_MAPSERVER-USERS] What does this error message mean?
>Date: Wed, 02 Aug 2006 17:56:49 -0500
>Why are you running an old, not to mention beta, version?
>That aside I don't see code here that would even invoke the lexer. That
>only happens with mapfile parsing and expression evaluation.
>Steve
> >>> "M.L. Jackson" <mljacks2 at hotmail.com> 08/02/06 2:54 PM >>>
>I'm on a Windows machine running mapscript 4.6.0-beta1.
>Shp2img runs on it fine. The map file is a map of the United States of
>America with a rivers layer, states layer, and wms layer.
>I'm running a JSP script. Yes, I have run a similar script on Tomcat.
>The
>script prints an interactive map legend using a Java Bean print method
>call.
>The Java Bean method looks like this:
>public String makeLegend()
>String layerName = "";
>int layerCount = map.getNumlayers();
>String legend = "";
>//check the layer for a space which will cause problems and display
>error
>message
>for(int i = 0; i < layerCount; i++)
> layerName = map.getLayer(i).getName();
> if(layerName.contains(" ")){
>legend += "<br><br><i><b><font color = red size = 2>The layer name \"" +
>layerName +
> "\" contains a space character and
>will not function
>correctly!!<br>" +
> "Find the layer in the map file
>and remove the space,
>then " +
> "reload the
>application.</font></b></i>";
> return legend;
>//generates html for check boxes
>legend = " <form name = \"legendForm\">";
>legend += "\n <input type = \"checkbox\" onclick =
>handleBoxes(\"" +
>layerName + "\")" +
> " name = \"" + layerName +
>"box\" checked>" + layerName.replace("_", "
>") + "</input><br><br>";
>legend += "\n </form>";
>return legend;
>Hope this is somewhat clear. Thanks.
> >To: "M.L. Jackson" <mljacks2 at hotmail.com>,
> ><MAPSERVER-USERS at lists.umn.edu>
> >Date: Wed, 02 Aug 2006 14:15:45 -0500
> >Hmmm... Haven't seen that one before. I've found very little on Google
> >with regards to the
> >error. Something tells me it has to do with something like an empty
> >file however I tried doing
> >that locally and got a more appropriate error. So, we'll need more
> >information.
> >- what platform? what version?
> >- what does the mapfile look like? can you run shp2img on it?
> >- have you run this or a similar script successfully under tomcat?
> >Steve
> > >>> "M.L. Jackson" <mljacks2 at HOTMAIL.COM> 8/2/2006 1:50:57 PM >>>
> >What does this mean? This message is generated when I try to run my
> >java
> >mapscript application on Tomcat.
> >"fatal flex scanner internal error--end of buffer missed"
> >_________________________________________________________________
> >Express yourself instantly with MSN Messenger! Download today - it's
> >FREE!
> >http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/
>FREE!
Dont just search. Find. Check out the new MSN Search!
http://search.msn.click-url.com/go/onm00200636ave/direct/01/
