What does this error message mean?
M.L. Jackson
mljacks2 at HOTMAIL.COM
Thu Aug 3 14:51:34 EDT 2006
Honestly, I downloaded this version as an update a while back and I remember
it being a pain so I haven't been looking forward to updating again. I
continued this project from someone else and always have to figure out where
all the files are located and what I actually need to download. I guess I
am now forced to update.
The reason I posted the code snippet is that the error only seems to show
when I add this code to my Java bean.
Thanks for your replies.
>From: "Steve Lime" <Steve.Lime at dnr.state.mn.us>
>To: <mljacks2 at hotmail.com>, <mapserver-users at lists.umn.edu>
>Subject: Re: [UMN_MAPSERVER-USERS] What does this error message mean?
>Date: Wed, 02 Aug 2006 17:56:49 -0500
>Why are you running an old, not to mention beta, version?
>That aside I don't see code here that would even invoke the lexer. That
>only happens with mapfile parsing and expression evaluation.
>Steve
> >>> "M.L. Jackson" <mljacks2 at hotmail.com> 08/02/06 2:54 PM >>>
>I'm on a Windows machine running mapscript 4.6.0-beta1.
>Shp2img runs on it fine. The map file is a map of the United States of
>America with a rivers layer, states layer, and wms layer.
>I'm running a JSP script. Yes, I have run a similar script on Tomcat.
>The
>script prints an interactive map legend using a Java Bean print method
>call.
>The Java Bean method looks like this:
>public String makeLegend()
>String layerName = "";
>int layerCount = map.getNumlayers();
>String legend = "";
>//check the layer for a space which will cause problems and display
>error
>message
>for(int i = 0; i < layerCount; i++)
> layerName = map.getLayer(i).getName();
> if(layerName.contains(" ")){
>legend += "<br><br><i><b><font color = red size = 2>The layer name \"" +
>layerName +
> "\" contains a space character and
>will not function
>correctly!!<br>" +
> "Find the layer in the map file
>and remove the space,
>then " +
> "reload the
>application.</font></b></i>";
> return legend;
>//generates html for check boxes
>legend = " <form name = \"legendForm\">";
>legend += "\n <input type = \"checkbox\" onclick =
>handleBoxes(\"" +
>layerName + "\")" +
> " name = \"" + layerName +
>"box\" checked>" + layerName.replace("_", "
>") + "</input><br><br>";
>legend += "\n </form>";
>return legend;
>Hope this is somewhat clear. Thanks.
> >To: "M.L. Jackson" <mljacks2 at hotmail.com>,
> ><MAPSERVER-USERS at lists.umn.edu>
> >Date: Wed, 02 Aug 2006 14:15:45 -0500
> >Hmmm... Haven't seen that one before. I've found very little on Google
> >with regards to the
> >error. Something tells me it has to do with something like an empty
> >file however I tried doing
> >that locally and got a more appropriate error. So, we'll need more
> >information.
> >- what platform? what version?
> >- what does the mapfile look like? can you run shp2img on it?
> >- have you run this or a similar script successfully under tomcat?
> >Steve
> > >>> "M.L. Jackson" <mljacks2 at HOTMAIL.COM> 8/2/2006 1:50:57 PM >>>
> >What does this mean? This message is generated when I try to run my
> >java
> >mapscript application on Tomcat.
> >"fatal flex scanner internal error--end of buffer missed"
> >_________________________________________________________________
> >Express yourself instantly with MSN Messenger! Download today - it's
> >FREE!
> >http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/
>FREE!
Dont just search. Find. Check out the new MSN Search!
http://search.msn.click-url.com/go/onm00200636ave/direct/01/
