width property for points?
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Fri Aug 4 16:51:29 EDT 2006
Mike: First, please file a quick bug on not saving width or antialias
and I'll fix
ASAP. Might also want to file one for applying width to the outline of
filled
symbols.
Second, you'll probably need 2 symbols: one with FILLED TRUE and the
other
without it (e.g. tent and tent-outline). I just looked at the code and
it respects
width for non-filled VECTOR symbols.
Steve
>>> Mike Leahy <mgleahy at GOLDEN.NET> 8/4/2006 3:24:49 PM >>>
Hello List,
I've been trying to see if I can style points with an outline that is
thicker than one pixel. Firstly, I've found that I am not able to set
the WIDTH property of a style element using MapScript - is this a Bug?
The MapServer FAQ suggest the following for Polygons:
STYLE # solid fill
COLOR 255 0 0
END
STYLE # thick outline (could use a circle symbol with size too)
OUTLINECOLOR 0 0 0
WIDTH 3
ANTIALIAS TRUE
END
This works if I manually edit the mapfile, but since MapScript won't
save the width property for me (or ANTIALIAS for that matter), I had to
use the following approach:
STYLE
ANGLE 360
COLOR 210 247 247
SYMBOL 0
END
STYLE
ANGLE 360
OUTLINECOLOR 0 0 255
SIZE 3
SYMBOL "circle"
END
I've tried similar methods for point symbols:
STYLE
COLOR 0 163 240
SIZE 9
SYMBOL "tent"
END
STYLE
SYMBOL "tent"
SIZE 9
OUTLINECOLOR 0 255 0
WIDTH 5
END
I've also tried:
STYLE
COLOR 0 163 240
SIZE 9
SYMBOL "tent"
WIDTH 5
END
Unfortunately, nothing I do makes the outline around the point any
thicker than one pixel. Has anyone else encountered this? I know I
could just put a smaller symbol on top of another, but that only works
if a relatively symmetrical symbol is used (like a circle or star).
Thanks in advance for any suggestions,
Mike
