ogr and mysql help!
lemay
tzzbzzgf at HOTMAIL.COM
Tue Aug 8 04:47:18 EDT 2006
hi,all:
I use ogr to connect mysql database and shp file with "left join" clause.and i only want to select some part of data from a mysql table ,how can i do ? Does ogr support "left join" and "where" clause together?
MAP
IMAGETYPE PNG
#EXTENT 73 10 137 53
EXTENT 116 27 124 35.5
UNITS DD
SIZE 400 300
#FONTSET "fonts/fonts.list"
SHAPEPATH "data"
IMAGECOLOR 255 255 255
LAYER # States polygon layer begins here
DEBUG ON
NAME jiangsu
STATUS DEFAULT
TYPE polygon
DEBUG ON
CONNECTIONTYPE ogr
CONNECTION "/ms4w/apps/gmap/data/jiangsu.shp"
#DATA "SELECT jiangsu_pro.*,test.* FROM jiangsu_pro left join 'MYSQL:test,host=localhost,user=root,password=491025,table types=memory'.test ON jiangsu_pro.JIANGSU_ID= test.Id"
#DATA "SELECT jiangsu_pro.*,mysqltest.* FROM jiangsu_pro left join 'MYSQL:test,host=localhost,user=root,password=491025,table types=memory'.mysqltest ON jiangsu_pro.JIANGSU_ID= mysqltest.Id where mysqltest.Area_data='3'"
DATA "SELECT * FROM jiangsu"
PROJECTION
"init=epsg:4609"
END
#CLASSITEM "test.Area_name"
#CLASSITEM "mysqltest.area_name"
CLASS
# EXPRESSION 'Ganyu'
COLOR 255 0 255
OUTLINECOLOR 0 132 32
END
END # States polygon layer ends here
END # end of map file/object
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060808/9c4de9ad/attachment.html
