HELP! Application Error - ArcSDE / MapServer 4.8
Mike Saunt
mikesaunt at GMAIL.COM
Thu Aug 10 09:51:02 EDT 2006
Hi All
I've got an issue with ArcSde and MapServer running in a windows
environment. I've copied the arcsde 9.1 libmap.dll and ogr_sde.dll into the
MS directory.
I have an ArcSDE 9.1 media pack client library installed on the mapserver
box and a remote server with ArcSde 8.3. I can connect - as when I have
invalid credentials I get valid errors return from MS - and I can find the
sde layers - if I have the wrong TYPE for the layer then I get an error
message from MS - all correct.
The issue arises that when I have the correct connection string and the
correct layer name I get an application error dialog box appearing with a
memory read error. I can't seem to get any debug messages via the
ms.logand also the mapserv -v via the command prompt says I have input
type SDE.
I'm sure it will be a little tweak but am starting to lose it a bit - also I
am on a client site so can't debug etc through the night.
LAYER
NAME Landline
TYPE POLYGON
STATUS default
CONNECTION "192.168.62.27,port:5156,UNI7,sde,sde"
CONNECTIONTYPE SDE
DATA "UNISDELIVE.UFRM_BCPLOT_POLY,SHAPE,SDE.DEFAULT"
CLASS
END
END
Has anyone come across this before?
Thanks in advance
Mike
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060810/8c80fea0/attachment.html
