HELP! Application Error - ArcSDE / MapServer 4.8
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Thu Aug 10 15:26:32 EDT 2006
Do you get any SDE error numbers? What is the exact error message?
Steve
>>> Mike Saunt <mikesaunt at GMAIL.COM> 8/10/2006 8:51:02 AM >>>
Hi All
I've got an issue with ArcSde and MapServer running in a windows
environment. I've copied the arcsde 9.1 libmap.dll and ogr_sde.dll into
the
MS directory.
I have an ArcSDE 9.1 media pack client library installed on the
mapserver
box and a remote server with ArcSde 8.3. I can connect - as when I
have
invalid credentials I get valid errors return from MS - and I can find
the
sde layers - if I have the wrong TYPE for the layer then I get an
error
message from MS - all correct.
The issue arises that when I have the correct connection string and
the
correct layer name I get an application error dialog box appearing with
a
memory read error. I can't seem to get any debug messages via the
ms.logand also the mapserv -v via the command prompt says I have input
type SDE.
I'm sure it will be a little tweak but am starting to lose it a bit -
also I
am on a client site so can't debug etc through the night.
LAYER
NAME Landline
TYPE POLYGON
STATUS default
CONNECTION "192.168.62.27,port:5156,UNI7,sde,sde"
CONNECTIONTYPE SDE
DATA "UNISDELIVE.UFRM_BCPLOT_POLY,SHAPE,SDE.DEFAULT"
CLASS
END
END
Has anyone come across this before?
Thanks in advance
Mike
