HELP! Application Error - ArcSDE / MapServer 4.8
    Mike Saunt
    mikesaunt at GMAIL.COM
    Thu Aug 10 13:44:37 PDT 2006
Hi Steve
Thanks for the response.  As it turns out I downloaded the latest MS4W from
about three weeks ago and loaded that libmap for SDE9.1 and it all worked!
I didn't see my message until I got your response and wasn't sure that it
had been sent through to the list.
Regards and thanks again
Mike
On 10/08/06, Steve Lime <Steve.Lime at dnr.state.mn.us> wrote:
> Do you get any SDE error numbers? What is the exact error message?
> Steve
> >>> Mike Saunt <mikesaunt at GMAIL.COM> 8/10/2006 8:51:02 AM >>>
> Hi All
> I've got an issue with ArcSde and MapServer running in a windows
> environment. I've copied the arcsde 9.1 libmap.dll and ogr_sde.dll into
> the
> MS directory.
> I have an ArcSDE 9.1 media pack client library installed on the
> mapserver
> box and a remote server with ArcSde 8.3.  I can connect - as when I
> have
> invalid credentials I get valid errors return from MS - and I can find
> the
> sde layers - if I have the wrong TYPE for the layer then I get an
> error
> message from MS - all correct.
> The issue arises that when I have the correct connection string and
> the
> correct layer name I get an application error dialog box appearing with
> a
> memory read error.  I can't seem to get any debug messages via the
> ms.logand also the mapserv -v via the command prompt says I have input
> type SDE.
> I'm sure it will be a little tweak but am starting to lose it a bit -
> also I
> am on a client site so can't debug etc through the night.
> LAYER
>   NAME Landline
>   TYPE POLYGON
>   STATUS default
>   CONNECTION "192.168.62.27,port:5156,UNI7,sde,sde"
>       CONNECTIONTYPE SDE
>       DATA "UNISDELIVE.UFRM_BCPLOT_POLY,SHAPE,SDE.DEFAULT"
>   CLASS
>   END
> END
> Has anyone come across this before?
> Thanks in advance
> Mike
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060810/74aeb46d/attachment.htm>
More information about the MapServer-users
