Property 'angle' does not exist in this object.
cj5
cj at ODEWEBDESIGNS.COM
Thu Aug 10 19:16:38 EDT 2006
I got this error in this PHP/Mapscripot code:
while($points = $lyr->nextShape()) {
//echo $points->index . "<br />";
$pointShp = $lyr->getShape(-1, $points->index);
$pt = ms_newPointObj();
$pt->setXY($pointShp->getValue($lyr, 'LONGITUDE'),
$pointShp->getValue($lyr, 'LATITUDE'));
$ln = ms_newLineObj();
$ln->add($pt);
$shp = ms_newShapeObj(MS_SHAPE_POINT);
$shp->add($ln);
$noWindStyle->set("angle", $pointShp->getValue($lyr, 'WINDDIR'));
if($pointShp->getValue($lyr, 'SPDMH') < 50) {
$shp->set("classindex", 1);
$shp->draw($map, $lyr, $image);
My main concern is the the line it refers to in the error message
Now I established that as a style object, and in the documentation it says
that there is an angle variable. So I'm confused as to why I'm getting this
error. Any ideas?
View this message in context: http://www.nabble.com/Property-%27angle%27-does-not-exist-in-this-object.-tf2087868.html#a5754439
Sent from the Mapserver - User forum at Nabble.com.
