installation PHP_Mapscript
Murat BEYHAN
beyhan at DEPREM.GOV.TR
Mon Aug 21 02:02:42 EDT 2006
Dear Daniel,
Thank you so much.
Success....
I have make an extensions directory under the php directory.
And I have indicate where I have created extensions directory in php.ini file
than I have copied php_mapscript.so file into the extensions directory.Then I
have try an example zooming and panning which is published on the mapservers
documentation page .
Then I have seen my map on the screen.
The second issue to make a connection with MySQL database to import data from
the database and publish on the map. Is it possible to do that by using
Mapserver...
Regards
MURAT
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
