schemas.opengeospatial.net has been shutdown,
use schemas.opengis.net instead
Daniel Morissette
dmorissette at MAPGEARS.COM
Wed Aug 23 14:12:41 EDT 2006
If you are running OGC Web Services (WMS, WFS, etc.) based on MapServer
and started getting reports from your users that your service suddenly
stopped working with some WMS/WFS clients, then this may be because
schemas.opengeospatial.net has been shutdown recently (see bug 1873).
This was the schema repository that MapServer was using by default since
version 4.4.
Future releases of MapServer will be fixed to use the (new?) official
OGC schema repository at schemas.opengis.net by default. In the
meantime, if you are still running older versions of MapServer, you can
work around the issue by setting the ows_schemas_location web metadata
in your mapfile:
MAP
WEB
METADATA
"ows_schemas_location" "http://schemas.opengis.net"
END
END
END
Daniel
Daniel Morissette
http://www.mapgears.com/
