schemas.opengeospatial.net has been shutdown,
use schemas.opengis.net instead
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Sat Aug 26 02:47:17 EDT 2006
Hi Daniel,
have you seen it's up again?
Maybe they got too many complaints?
Best regards,
Bart
Daniel Morissette wrote:
> If you are running OGC Web Services (WMS, WFS, etc.) based on
> MapServer and started getting reports from your users that your
> service suddenly stopped working with some WMS/WFS clients, then this
> may be because schemas.opengeospatial.net has been shutdown recently
> (see bug 1873). This was the schema repository that MapServer was
> using by default since version 4.4.
> Future releases of MapServer will be fixed to use the (new?) official
> OGC schema repository at schemas.opengis.net by default. In the
> meantime, if you are still running older versions of MapServer, you
> can work around the issue by setting the ows_schemas_location web
> metadata in your mapfile:
> MAP
> WEB
> METADATA
> "ows_schemas_location" "http://schemas.opengis.net"
> END
> END
> END
> Daniel
OSGIS, Open Source GIS
http://www.osgis.nl
