Setting expiry date for a layer
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Thu Aug 24 13:09:18 EDT 2006
One simple way to achieve this would be to write a simple wrapper in a
script that would emit the appropriate headers before spooling the image
to the browser.
-Steve W
Ludwig Max Brinckmann wrote:
> I have a map layer reading from a PostGIS database that is being
> populated asynchronously through a separate process in the background.
> My mapclient displays this data through a WMS request and merges it on
> the fly (openlayers-like) with WMS layers coming from other sources.
> While most of the layers are static ( i.e. do not change over time), my
> PostGIS layer is highly dynamic and displaying up-to-date information is
> crucial to the application.
> Currently, whenever refreshing the map image, the browser will simply
> fetch the image again from the cache, meaning that the viewer displays
> old data.
> Is there a way in mapserver to set the expiration time of the image
> supplied, so that my mapping client would automatically refresh, rather
> than reload the old image from the browser cache? (it is good enough for
> the application to refresh every time, rather than only when Postgis has
> changed, so simply setting the expiry time in the http header would be
> great)
> Ludwig
