PostGIS case problem
Jacolin Yves
yjacolin at FREE.FR
Wed Aug 30 07:21:24 EDT 2006
Sorry to not post a message before. But I confim that postgis doesn't like
capital letter. I don't know if mapserver change something in the
'connection' parameter. But when I create a table in the postGIS database,
with capital letter, the layername in the 'geometry_columns' table was in
capital letter but the layer name (ie the name of the table) was in lower
case !
Regards,
Y.
Le Mercredi 30 Août 2006 12:40, Daniel Vencler a écrit :
> Sebastian Walter wrote:
> > Hi Daniel,
> > According to my map file, I would use
> > DATA "Geometrija FROM Objekti_Uprave"
> > (without single quotes, double quotes around the whole expression).
> > Perhaps this will work for you also...
> > Probably postgres will have trouble with the underscore (_). In this
> > case, try to rename the table...
> Nope, it will not help. I have tried following. I have create
> new table in lower case and it worked, but if just one attribute is
> renamed with firt capital letter then mapserver gives me empty WFS
> reply (only BBox). There is definitely some problem with mapserver and
> postgis.
> Best regards,
> Daniel Vencler
Yves Jacolin
http://yjacolin.gloobe.org
Stagiaire Conservatoire Régional des Espaces Naturels de la région Centre
http://cahiersnaturalistes.free.fr/cpnrc/
- Qu'est-ce que cela peut faire que je lutte pour la mauvaise cause
puisque je suis de bonne foi?
- Et qu'est-ce que ça peut faire que je sois de mauvaise foi
puisque c'est pour la bonne cause. (Jacques Prévert)
