php_mapscript_48.dll issues
Eijnden, B. van den (Bart)
b.vdeijnden at AGI.RWS.MINVENW.NL
Sun Feb 12 22:11:18 PST 2006
Are you running PHP as a module? Then you cannot use the dl function. Just
add php_mapscript48.dll to your list of extensions in php.ini like the error
message says, or run PHP as a CGI.
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens
Luke Savage
Verzonden: maandag 13 februari 2006 6:13
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: [UMN_MAPSERVER-USERS] php_mapscript_48.dll issues
Hello Users,
I haven't been able to connect to php_mapscript_48.dll using the
mapserver-4.8.1-win32-php5.1.2.zip installation package from maptools.org.
The error is below. I have followed the installation text document but it
seems the extension in the php.ini file is not able to run the extension.
PHP is coming up just fine but the extension is not running. I have placed
the DLL in system32, php root, php/ext, mapserver_binaries, system...I've
run out of ideas on troubleshooting this problem. Any help would be much
appreciated.
Specs:
Apache 2.0.55
PHP 5.1.2
Mapserver 4.8.1
Warning: dl() [ function.dl <http://localhost/function.dl> ]: Not supported
in multithreaded Web servers - use extension=php_mapscript_48.dll in your
php.ini in C:\apache\Apache2\htdocs\php_hello.php on line 1
Testing php file...
<?php dl("php_mapscript_48.dll");
phpinfo();
Luke Savage
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060212/bdcfad65/attachment.htm>
More information about the MapServer-users
