HTML legend not created in mapserver 4.6.1
Vito Meuli
vito.meuli at TECNOLOGIEAVANZATE.IT
Fri Jan 20 12:14:21 EST 2006
Hi Jeff!
I'd really appreciate your help!
I'm sending you an archive with the most streamlined mapfile I can write that
still reproduce my problem, along with the shapefiles and other stuff it
needs to work (the mailing list will not get the attached file).
The mapfile is almos 400 lines long, so I'll post it on the list only if
needed.
It seems that even if I modify a single character in the mapfile, the problem
goes away!
Even the IMAGEURL seems to trigger the problem!
If I let it be
IMAGEURL "/tmp/"
then the problems goes away!
It seems to be somewhat random...
The map file is named spancrazioPDF_modificatoVITOMEULI.map and I use a
strange couple of files as templates, one for the map, template.xml, and one
for the HTML legend, legenda.html. They are needed for a J2EE application
that encapsulates Mapserver.
Normally I test the problem executing directly mapserver from the browser with
an address like:
http://localhost/cgi-bin/mapserv-4.6.1?map=/varGIS/sanpancraziotest/spancrazioPDF_modificatoVITOMEULI.map
and I should get from the template a long list of text and tiny images that
will go in the legend, like:
11377746807088 /sanpancrazio_data/tmp/SPANCRAZIO_11377746807088.png
/sanpancrazio_data/tmp/SPANCRAZIO_ref11377746807088.png
/sanpancrazio_data/tmp/SPANCRAZIO_sb11377746807088.png 76496.163158
2749173.047250 4470954.175000 2770761.952750 4487125.825000 800 600
-1.000000 -1.000000 Piano di Fabbricazione Visibilita' [if
name=cliccabile value=SI] [/if] Strada di P.R.G. [metadata name=visibilita]
[if name=cliccabile value=SI] [/if] Centro Storico [metadata
name=visibilita] [if name=cliccabile value=SI] [/if] Edilizia esistente
[metadata name=visibilita] [if name=cliccabile value=SI] [/if] Zona
Semintensiva [metadata name=visibilita] [if name=cliccabile value=SI] [/if]
Zona Direzionale [metadata name=visibilita] [if name=cliccabile value=SI]
[/if] Zona Estensiva [metadata name=visibilita] [if name=cliccabile
value=SI] [/if] Zona per Artigianato [metadata name=visibilita] [if
name=cliccabile value=SI] [/if] Zona Industriale [metadata name=visibilita]
[if name=cliccabile value=SI] [/if] Zona Agricola [metadata name=visibilita]
Edifici e costruzioni Visibilita' [if name=cliccabile value=SI] [/if]
Albero isolato [metadata name=visibilita] [if name=cliccabile value=SI] [/if]
Punti quotati a terra [metadata name=visibilita] [if name=cliccabile
value=SI] [/if] Quota colmo tetto [metadata name=visibilita] [if
name=cliccabile value=SI] [/if] Quota colmo tetto manufatto minore [metadata
name=visibilita] [if name=cliccabile value=SI] [/if] Quota gronda tetto
[metadata name=visibilita] [if name=cliccabile value=SI] [/if] Quota gronda
tetto manufatto minore [metadata name=visibilita] [if name=cliccabile
value=SI] [/if] Quota tetto manufatto minore [metadata name=visibilita] [if
name=cliccabile value=SI] [/if] Quota tetto piano [metadata name=visibilita]
[if name=cliccabile value=SI] [/if] Quota tetto piano manufatto minore
[metadata name=visibilita] [if name=cliccabile value=SI] [/if] Quota tetto
torrino [metadata name=visibilita] Sistema mobilita' Visibilita' [if
name=cliccabile value=SI] [/if] Rete ferroviaria FSE [metadata
name=visibilita] [if name=cliccabile value=SI] [/if] Strade provinciali
[metadata name=visibilita] [if name=cliccabile value=SI] [/if] Strade
statali [metadata name=visibilita] [if name=cliccabile value=SI] [/if]
Strade comunali [metadata name=visibilita] Elementi cartografici
Visibilita' [if name=cliccabile value=SI] [/if] Marciapiedi [metadata
name=visibilita]
Instead, when there is the problem, I do not get the legend part, like the
following:
11377736317029 /sanpancrazio_data/tmp/SPANCRAZIO_11377736317029.png
/sanpancrazio_data/tmp/SPANCRAZIO_ref11377736317029.png
/sanpancrazio_data/tmp/SPANCRAZIO_sb11377736317029.png 76305.159315
2749200.000000 4470964.375000 2770735.000000 4487115.625000 800 600
-1.000000 -1.000000
and no error message.
I get the same problem with the CGI-BIN mapserver 4.6.1 and 4.4.2.
No problem with 4.2.3 and 4.2.5, that unfortunately have other bugs.
I compiled mapserver 4.6.1 on a Red Hat Enterprise Linux AS 4, and I compiled
all these libraries and programs:
zlib-1.2.3
proj-4.4.9
libpng-1.2.8-config
jpeg-6b
tiff-3.7.4
libgeotiff-1.2.2
freetype-2.1.10
gd-2.0.33
geos-2.1.4
postgresql-8.0.4
postgis-1.0.4
ecwsdk-3.1.25 (not compiled by me)
gdal-1.3.1
fcgi-2.4.0
mod_fastcgi-2.4.2
The configure command was like this:
./configure \
--with-freetype=/usr/local/bin/freetype-config \
--with-zlib=/usr/local \
--with-png=/usr/local \
--with-jpeg=/usr/local \
--with-gd=/usr/local \
--with-proj=/usr/local \
--with-threads \
--with-geos=/usr/local/bin/geos-config \
--with-gdal=/usr/local/bin/gdal-config \
--with-tiff=/usr/local \
--with-postgis=/usr/local/pgsql/bin/pg_config \
--with-ogr=/usr/local/bin/gdal-config \
--with-wfs \
--with-wcs \
--with-wmsclient \
--with-wfsclient \
--with-fastcgi=/usr/local
I hope you can manage to discover the cause of this problem.
Thanks a lot!
Cheers,
Vito Meuli
Alle 21:25, venerdì 13 gennaio 2006, hai scritto:
> Hi Vito,
> I'm not sure either what is going on in your case (although i'm not a
> developer). The best i can offer is to test it for you, so if you make
> your test as streamlined as possible (create the smallest mapfile that
> you can to reproduce your problem, with the fewest amount of
> layers/classes/groups) i can try it for you.
> jeff
