HTML Legend Template File
Sievers, Jason
jsievers at CO.LINN.OR.US
Tue Jun 6 18:50:58 EDT 2006
I have an HTML legend template file that is causing me problems. I enter
the file, do some stuff, everything works fine. But in a JavaScript block
of code I can get through a couple JavaScript statements but then the
template file is exited and returns to where it was before calling the
template file. Here is the code for the legend template file.
[leg_layer_html order_metadata=orderby opt_flag=15]
[if name=display oper=isset]
<SCRIPT>
var annodes =
Anno_ReturnNodes("[leg_layer_name]");
var thislayername = "[leg_layer_name]";
var thisdisplay = "";
var thegrp = "";
var spc = "";
var clsspc = " ";
var layos = 0;
var clsos = 15;
var linei = -1;
</SCRIPT>
[if name=grp oper=isset]
<SCRIPT>
thisdisplay = "[metadata
name=grp]";
layos = 15;
clsos = 30;
thegrp = thisdisplay +
"_GROUP";
</SCRIPT>
[/if]
[/if]
[/leg_layer_html]
The last JavaScript statement "thegrp = thisdisplay + "_GROUP";" is where
the exit occurs. When I remove this line from the code all works fine
again. I know that there is nothing wrong with this line of code and so am
confused as to what is going on. Also I have tested by removing that last
line of JavaScript code and then inserted several carriage returns. This
also breaks the template file and causes an exit. I am very confused by
this am open to any thoughts.
Thanks,
Jason Sievers
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060606/6ac97c1a/attachment.html
