server error
Manfred Meier
m.meier at SPIEKERMANN.DE
Sat Jun 10 12:03:34 EDT 2006
Hello,
- are you sure that there are no error messages in the apache log in the
last 5 or so lines before the "Premature end of script headers."? If you
are not sure, perhaps you can give us the last 10 lines of your log file.
- Does the same Map-File work with shp2img : shp2img -m mapfile. I use
this "debugging" method sometimes becaus it gives you the error messages
on the screen
Manfred Meier
Matthew Kane schrieb:
> I'm quite a newbie with MapServer and am having problems with server
> errors. I am going through the book "Beginning MapServer" and some of
> his maps execute just fine, but others generate a 500 Internal Server
> Error.
> The Apache error log isn't very helpful. It just states: Premature end
> of script headers.
> Any suggestions on how to track down the problem would be greatly
> appreciated.
> -Matt
