server error
Matthew Kane
markane at INDIANA.EDU
Mon Jun 12 22:11:13 EDT 2006
Thanks for your suggestion, Manfred.
I am sure there are no other error message in the apache log.
I have ran the mapfile using shp2img and the result is not an error message;
rather, I get a Segmentation Fault. Any idea what would cause this?
Thanks,
Matt
On 6/10/06, Manfred Meier <m.meier at spiekermann.de> wrote:
> Hello,
> - are you sure that there are no error messages in the apache log in the
> last 5 or so lines before the "Premature end of script headers."? If you
> are not sure, perhaps you can give us the last 10 lines of your log file.
> - Does the same Map-File work with shp2img : shp2img -m mapfile. I use
> this "debugging" method sometimes becaus it gives you the error messages
> on the screen
> Manfred Meier
> Matthew Kane schrieb:
> > I'm quite a newbie with MapServer and am having problems with server
> > errors. I am going through the book "Beginning MapServer" and some of
> > his maps execute just fine, but others generate a 500 Internal Server
> > Error.
> > The Apache error log isn't very helpful. It just states: Premature end
> > of script headers.
> > Any suggestions on how to track down the problem would be greatly
> > appreciated.
> > -Matt
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060612/816bbd6e/attachment.html
