MapServer returns cached images as new
Eijnden, B. van den (Bart)
b.vdeijnden at AGI.RWS.MINVENW.NL
Thu Jun 15 06:27:04 EDT 2006
No unfortunately the patch did not work for me.
I really hope it does get fixed in 4.9, since otherwise running PHP as a
module is still problematic and needs workarounds.
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: antti siukola [mailto:siukola.antti at gmail.com]
Verzonden: donderdag 15 juni 2006 12:04
Aan: Eijnden, B. van den (Bart)
CC: MAPSERVER-USERS at lists.umn.edu
Onderwerp: Re: [UMN_MAPSERVER-USERS] MapServer returns cached images as
new
Did you get that patch working? The target milestone seems to be for
4.8 so we can expect it to be implemented in 4.9 serie at the latest?
Maybe ;)
On 6/15/06, Eijnden, B. van den (Bart) <b.vdeijnden at agi.rws.minvenw.nl>
wrote:
> It's still a known issue unfortunately, check:
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1322
> Best regards,
> Bart
> Verzonden: donderdag 15 juni 2006 9:35
> new
> Yes I am
> AnttiS
> wrote:
> > Are you using PHP/Mapscript? As an Apache module?
> > Best regards,
> > Bart
> > Van: UMN MapServer Users List
> > [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens antti
> siukola
> > Verzonden: donderdag 15 juni 2006 8:44
> > Aan: MAPSERVER-USERS at LISTS.UMN.EDU
> > Onderwerp: [UMN_MAPSERVER-USERS] MapServer returns cached images as new
> > Hi!
> > I've have a problem with mapserver returning images from cache when
> > navigating on the map. Totally random behavior. Is there some
> > configuration for this or is this a bug?
> > AnttiS
> > Disclaimer
> > Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
> > uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
> hebt
> > ontvangen, wordt u verzocht het te vernietigen en de afzender te
> informeren.
> > Wij adviseren u om bij twijfel over de juistheid of de volledigheid van
de
> > mail contact met afzender op te nemen. This message shall not constitute
> any
> > rights or obligations. This message is intended solely for the
addressee.
> If
> > you have received this message in error, please delete it and notify the
> > sender immediately. When in doubt whether this message is correct or
> > complete, please contact the sender.
> Disclaimer
hebt
informeren.
> Wij adviseren u om bij twijfel over de juistheid of de volledigheid van de
any
> rights or obligations. This message is intended solely for the addressee.
If
Disclaimer
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060615/a4993666/attachment.html
