MapServer returns cached images as new
antti siukola
siukola.antti at GMAIL.COM
Wed Jun 28 08:45:46 EDT 2006
Hi!
I solved this problem by using saveImage function instead of
saveWebImage and generating the filename with md5 from users ip, php's
microtime and some random numbers. Also had to tell the imagepath and
imageurl manually. This seems to work pretty well.
AnttiS
On 6/15/06, Eijnden, B. van den (Bart) <b.vdeijnden at agi.rws.minvenw.nl> wrote:
> No unfortunately the patch did not work for me.
> I really hope it does get fixed in 4.9, since otherwise running PHP as a
> module is still problematic and needs workarounds.
> Best regards,
> Bart
> -----Oorspronkelijk bericht-----
> Van: antti siukola [mailto:siukola.antti at gmail.com]
> Verzonden: donderdag 15 juni 2006 12:04
> Aan: Eijnden, B. van den (Bart)
> CC: MAPSERVER-USERS at lists.umn.edu
> Onderwerp: Re: [UMN_MAPSERVER-USERS] MapServer returns cached images as
> new
> Did you get that patch working? The target milestone seems to be for
> 4.8 so we can expect it to be implemented in 4.9 serie at the latest?
> Maybe ;)
> wrote:
> > It's still a known issue unfortunately, check:
> > http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1322
> > Best regards,
> > Bart
> > Verzonden: donderdag 15 juni 2006 9:35
> > new
> > Yes I am
> > AnttiS
> > wrote:
> > > Are you using PHP/Mapscript? As an Apache module?
> > > Best regards,
> > > Bart
> > > Van: UMN MapServer Users List
> > > [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens antti
> > siukola
> > > Verzonden: donderdag 15 juni 2006 8:44
> > > Aan: MAPSERVER-USERS at LISTS.UMN.EDU
> > > Onderwerp: [UMN_MAPSERVER-USERS] MapServer returns cached images as new
> > > Hi!
> > > I've have a problem with mapserver returning images from cache when
> > > navigating on the map. Totally random behavior. Is there some
> > > configuration for this or is this a bug?
> > > AnttiS
> > > Disclaimer
> > > Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
> > > uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
> > hebt
> > > ontvangen, wordt u verzocht het te vernietigen en de afzender te
> > informeren.
> > > Wij adviseren u om bij twijfel over de juistheid of de volledigheid van
> de
> > > mail contact met afzender op te nemen. This message shall not constitute
> > any
> > > rights or obligations. This message is intended solely for the
> addressee.
> > If
> > > you have received this message in error, please delete it and notify the
> > > sender immediately. When in doubt whether this message is correct or
> > > complete, please contact the sender.
> > Disclaimer
> hebt
> informeren.
> > Wij adviseren u om bij twijfel over de juistheid of de volledigheid van de
> any
> > rights or obligations. This message is intended solely for the addressee.
> If
> Disclaimer
> uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis hebt
> ontvangen, wordt u verzocht het te vernietigen en de afzender te informeren.
> mail contact met afzender op te nemen. This message shall not constitute any
> rights or obligations. This message is intended solely for the addressee. If
