WMS Capabilities: LatLonBoundingBox
Arnaud Diederen
ad at IONICSOFT.COM
Fri Jun 16 03:36:32 EDT 2006
Hi Bart,
Bart van den Eijnden (OSGIS) wrote:
> Hi Arnaud,
> the reason is probably that it costs performance to go through the
> projection layer.
> For some things, like the simple demo, projection is not necessary
> (all layers are shown unprojected), but for WMS it is necessary.
Fair enough!
> I think it could be a good idea to have a warning in the WMS
> GetCapabilities response that no projection was defined for the layer.
It seems like it is common practice to inspect (with the eyes) the
Capabilities for an OGC service which behaves a weird way, so it might
be a useful feature indeed.
Best Regards,
Arnaud
> Best regards,
> Bart
> Arnaud Diederen wrote:
>> Hi Angus,
>> I'm not using PostGIS layers; this is the Itasca demo for mapserver
>> 4.x, and putting the PROJECTION param fixes it, indeed!
>> I wonder why it is not put (uncommented, actually) in the vanilla
>> demo package. Is there a reason?
>> Thank you very much for the information!
>> Best regards,
>> Arnaud
>> Angus Dickey wrote:
>>> I am having a similar problem. Apparently Mapserver will
>>> automatically calculate the bounding box if you define it using epsg
>>> codes in the map file ex:
>>> PROJECTION
>>> "init=epsg:4269"
>>> END
>>> This works for me when I use shapefiles, i.e. it calculates the
>>> correct bounding box in the right coordinates, however all my
>>> Postgis layers end up with a bounding box of:
>>> minx="-2.5e+07" miny="-2.5e+07" maxx="2.5e+07" maxy="2.5e+07"
>>> Are youusing postgis layers? Does anybody know how to get mapserver
>>> to calculate the correct bounding box for postgis layers?
>>> Thanks for any help,
>>> ~Angus
>>> -----Original Message-----
>>> From: Arnaud Diederen [mailto:ad at IONICSOFT.COM] Sent: June 15, 2006
>>> 7:17 AM
>>> To: MAPSERVER-USERS at LISTS.UMN.EDU
>>> Subject: [UMN_MAPSERVER-USERS] WMS Capabilities: LatLonBoundingBox
>>> Hello,
>>> I'm absolutely new to mapserver, so I downloaded the demo for the
>>> 4.x version (I'm using Debian GNU/Linux).
>>> The demo pages work ok, but when I do a GetCapabilities operation
>>> (http://localhost/cgi-bin/mapserv?service=WMS&version=1.3&map=/var/www/workshop/itasca.map&request=GetCapabilities
>>> - local intranet, sorry :( ), I get the attached XML document.
>>> What I'm wondering is why the LatLonBoundingBox tags holds those
>>> values, since they are supposed to be in 4326, if I read the WMS
>>> spec right.
>>> Am I doing something wrong?
>>> I looked the archives, and googled the internet, but I couldn't find
>>> any help on this exact topic.
>>> I would definitely appreciate if somebody could provide any kind of
>>> help; would it be just pointers on what I have to do/fix.
>>> Best regards,
>>> Arnaud
