oracle spatial
Zhonghai Wang zhonghaiw at GMAIL.COM
Fri Jun 16 07:50:54 PDT 2006
It's a little bit weird, I've test the version MS4W1.5.3 again, It also does
not work. The same as MS4W2.0, with the command shp2img there is no problem
to generate the map image. my MapFile contains both connectiontypes, this is
the mapfile snippets:
LAYER
    NAME "SEARCHZIP POLYGON"
    TYPE POLYGON
    STATUS DEFAULT
    CONNECTIONTYPE ORACLESPATIAL
    CONNECTION "Ar/Ar at GIS2"
    DATA "GEOLOC FROM SEARCHZIP USING NONE"
    CLASS
      NAME "ZIPAREA"
      COLOR 153 153 153
    END
  END
  LAYER
    NAME "SEARCHCITY POLYGON"
    TYPE POLYGON
    STATUS DEFAULT
    CONNECTIONTYPE OGR
    CONNECTION "OCI:Ar/Ar at GIS2"
    DATA "SEARCHCITY"
    CLASS
      NAME "CITIES"
      COLOR 207 189 0
    END
  END
thanks for any hints to solve this problem.
zhonghai
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060616/0d66c444/attachment.htm>
More information about the MapServer-users mailing list
