oracle spatial
Daniel Goetz
madprof at GMX.CH
Mon Jun 19 03:33:24 EDT 2006
Hi Jeff,
I installed the ms4w 1.5.3 package on my computer, did the .dll swapping and as you prompted everything works fine. I can show oracle data via "OGR" and via "native" mapserver supprot. And I can map all other file-based formats and can combine them with oracle spatial data.
Thank you all so much for your help. I am really thankful for your assistance. Thank you.
regards
Daniel
P.S. And please let me know, when the problems with the libmap.dll (for oracle support) in the ms4w 2.0 package are fixed. Thank you.
-------- Original-Nachricht --------
Datum: Fri, 16 Jun 2006 16:50:54 +0200
Von: Zhonghai Wang <zhonghaiw at GMAIL.COM>
An: MAPSERVER-USERS at LISTS.UMN.EDU
Betreff: Re: [UMN_MAPSERVER-USERS] RE : oracle spatial
> It's a little bit weird, I've test the version MS4W1.5.3 again, It also
> does
> not work. The same as MS4W2.0, with the command shp2img there is no
> problem
> to generate the map image. my MapFile contains both connectiontypes, this
> is
> the mapfile snippets:
> LAYER
> NAME "SEARCHZIP POLYGON"
> TYPE POLYGON
> STATUS DEFAULT
> CONNECTIONTYPE ORACLESPATIAL
> CONNECTION "Ar/Ar at GIS2"
> DATA "GEOLOC FROM SEARCHZIP USING NONE"
> CLASS
> NAME "ZIPAREA"
> COLOR 153 153 153
> END
> END
> LAYER
> NAME "SEARCHCITY POLYGON"
> TYPE POLYGON
> STATUS DEFAULT
> CONNECTIONTYPE OGR
> CONNECTION "OCI:Ar/Ar at GIS2"
> DATA "SEARCHCITY"
> CLASS
> NAME "CITIES"
> COLOR 207 189 0
> END
> END
> thanks for any hints to solve this problem.
> zhonghai
"Feel free" – 10 GB Mailbox, 100 FreeSMS/Monat ...
Jetzt GMX TopMail testen: http://www.gmx.net/de/go/topmail
