dl(): Unable to load dynamic library
Manfred Meier
m.meier at SPIEKERMANN.DE
Thu Jun 22 00:17:09 EDT 2006
Hello,
I'm not a real system administrator, so i know only little about that.
Some days ago i had a similar problem. To solve it, i copied the
libraries in question to a dir which is known to the system, e.g.
/usr/local/lib. Then i did 'ldconfig'. I did not alter the /etc/ld.so.conf.
Manfred
ramesh karra schrieb:
> No. I did not.
> Do you mean that I should add my library path to
> /etc/ld.so.conf and then do 'ldconfig'?
> What if I do not have the superuser permissions?
> Ramesh
> --- Manfred Meier <m.meier at SPIEKERMANN.DE> wrote:
>>Hi, did you do 'ldconfig' after copying the shared
>>libraries, so that
>>the cache is rebuilt?
>>Manfred
>>>Hi,
>>>I have been using mapserver + kaMap successfully
>>in
>>>windows environment for some time.
>>>Now, I am in the process of moving this to Linux
>>>environment. Since the Linux box is already
>>running
>>>Apache server, I did not choose to install the
>>>rpm/fgs. Instead I have manually copied the files.
>>>Now, I am getting the following error
>>>'./php_mapscript_4.8.2.so' - libmap.so.4.8.2:
>>cannot
>>>open shared object file: No such file or
>>directory in
>>>/users/krm/htdocs/init.php on line 106
>>>Fatal error: Call to undefined function:
>>>ms_newmapobj() in /users/krm/htdocs/init.php line
>>113
>>>I'd really appreciate any help in resolving this.
>>>Thanks
>>>Ramesh
>>>__________________________________________________
>>>Do You Yahoo!?
>>>Tired of spam? Yahoo! Mail has the best spam
>>protection around
>>>http://mail.yahoo.com
> Do You Yahoo!?
> Tired of spam? Yahoo! Mail has the best spam protection around
