how to build a geofence app.
Luis Treviño Huerta
ltrevino at GPOBSI.COM.MX
Fri Jun 23 18:20:38 EDT 2006
Thanks steve for the fast reply.
I'll give it a try.
Luis T.
----- Original Message -----
From: "Stephen Woodbridge" <woodbri at swoodbridge.com>
To: "Luis Treviño Huerta" <ltrevino at GPOBSI.COM.MX>
Cc: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Friday, June 23, 2006 5:01 PM
Subject: Re: [UMN_MAPSERVER-USERS] how to build a geofence app.
> Luis,
> I think the strategy for this would be to have an application like ka-map
> that allows the user to pan and zoom the map, then let the user start a
> geofence by digitizing points over the map. when they are done, submit the
> points back to the server and save them in a postgres or whatever. You can
> then compare the polygon to a lat/long and see if it is in/out of the
> polygon.
> -Steve W.
> Luis Treviño Huerta wrote:
>> Hi list,
>> Any idea, suggestion, howto, info source, whatever. of how can I build a
>> GeoFence application with mapserver?
>> I would like that the user is able to click over the map in order to
>> build it´s own geofence. Is it posible.
>> Regards,
>> Luis
