WMS Layer Problem
M.L. Jackson
mljacks2 at HOTMAIL.COM
Mon Jun 26 12:06:33 EDT 2006
Thanks for the reply. I tried changing the bounding box and still nothing.
I even removed all the layers except the wms layer to make sure it wasn't
any conflict with the other layers.
I noticed this message in red after I stopped the Tomcat server. It has
only appeared a few times after stopping the server.
HTTP: Starting to prepare HTTP requests.
HTTP request: id=2,
http://terraservice.net/OgcMap.ashx?LAYERS=DOQ&REQUEST=GetMap&SERVICE=WMS&FORMAT=image%2Fpng&STYLES=&HEIGHT=600&VERSION=1.1.1&SRS=EPSG:4326&WIDTH=800&BBOX=%2D178%2E217598362366%2C3%2E44738582890752%2C%2D66%2E9692710360024%2C86%2E8836313236801&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage
HTTP: Before download loop
msHTTPWriteFct(id=2, 396 bytes)
HTTP: After download loop
msHTTPExecuteRequests() timing summary per layer (connect_time +
time_to_first_packet + download_time = total_time in seconds)
Layer 2: 0.062 + 0.703 + 0.062 = 0.827s
msDrawRasterLayerLow(photo): entering.
Do you think that it is possible that the url for this layer is somehow
being requested exactly how it appears in this Tomcat message?
>From: Brock Anderson <banders at REFRACTIONS.NET>
>Reply-To: Brock Anderson <banders at REFRACTIONS.NET>
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: Re: [UMN_MAPSERVER-USERS] WMS Layer Problem
>Date: Mon, 26 Jun 2006 08:50:19 -0700
>I made a WMS request in my browser using the request parameters specified
>in your photo layer:
>http://terraservice.net/OgcMap.ashx?request=getmap&service=wms&version=1.1.1&width=500&height=500&layers=DOQ&bbox=-170,60,-150,75&srs=EPSG:4326&format=png
>The WMS gave an error: "Invalid Lon-Lat coordinates, must specify at least
>one (lon,lat) pair correctly; Longitude must be between -170 and -60
>Latitude must be between 15 and 75 "
>With a different lat-long bounding box it seems to work. I tested with
>bbox=-124,46,-110,52. I think the source WMS server doesn't like your
>bounding box.
>That's just a guess. I don't know exactly what WMS URLs mapserver is using
>to request the photo layers. If you have a way to intercept those outgoing
>URLs that should give you enough clues to fix the problem.
>Brock
>M.L. Jackson wrote:
>>Hi, I'm new to the Mapserver Listserv. I am having problems displaying the
>>wms layer on my map. My problem is that I don't see any aerial shots at
>>all. It is as if the map is being drawn without the layer.
>>Here is a snippet out of my map file where the wms layer is defined:
>>LAYER
>>NAME "photo"
>>STATUS DEFAULT
>>TYPE RASTER
>>MINSCALE 10000
>>#MAXSCALE 10000
>>CONNECTIONTYPE WMS
>>CONNECTION "http://terraservice.net/OgcMap.ashx?"
>>METADATA
>>"wms_srs" "EPSG:4326"
>>"wms_title" "Orthophoto"
>>"wms_name" "DOQ"
>>"wms_server_version" "1.1.1"
>>"wms_format" "image/png"
>>"wms_layers" "doq"
>>"wms_group_title" "background"
>>"wms_onlineresource" "http://terraservice.net/OgcMap.ashx?"
>>"wms_latlonboundingbox" "-170 -60 15 75"
>>#"wms_connectiontimeout" "120"
>>END
>>PROJECTION
>>"init=epsg:4326"
>>END
>>DEBUG ON
>>END
>>BTW, my map extent is -178.21759836236586 18.924781799316406
>>-66.96927103600244 71.40623535327121. Thanks for your reply.
>>_________________________________________________________________
>>Dont just search. Find. Check out the new MSN Search!
>>http://search.msn.click-url.com/go/onm00200636ave/direct/01/
