Asynchrone clients?
Marcos Cobeña marcoscobena at GMAIL.COM
Thu Jun 29 08:45:24 PDT 2006
Hi Eduard,
Give a try to OpenLayers (http://openlayers.org/), just cool. :-)
Regards,
2006/6/29, Eduard Witteveen <e.witteveen at hawarit.com>:
> Hello,
> Does anyone know a asynchrone (opensource) web-clients that retrieve
> gisdata?
> I would like to use a client that keeps retrieving data from the area ,
> but in which you can also click / pan / zoom in the meantime(with
> keeping already loaded vector data).
> If i would have to implement it i know it can be done by using the
> "google" way of retrieving square's of data. Is there also a way to make
> a streaming sollution with mapserver, or should i write my own server
> using GDAL directly..(fetch objects around a certain coordinate with
> ((distance to coordinate) * area) as order for which one to send first)
> Any thoughts?
> Ing. Eduard Yeb Witteveen           Software Engineer
> Hawar Information Technology bv   lid Dijkoraad Groep
> De Wymerts 7  8701 WT                        Bolsward
> Tel: +31 (0)515 570333         Fax: +31 (0)515 570335
> http://www.hawarit.com/             nl_NL fy_NL en_US
Marcos - http://www.youcannoteatbits.org
More information about the MapServer-users mailing list
