mapscript + inline features
listuser HH
listuser at HERZSYS.DE
Thu Jun 29 11:42:39 EDT 2006
Hi all,
i'm using java mapscript from ms4w and i try to query a layer with
inline feature (no direct data source).
I get the correct count of results from a querybyrect but i can't get
the feature and it's values. This is because the resultCacheObj has an
index of -1. So it is not possible to use the getFeature. The getFeature
works for the inline features if i use a possible index like 0.
Any hint / solution?
Best regards
Norbert
test.java
public class InlineFeatureTest {
public static void main(String[] args) {
URL mapURL = InlineFeatureTest.class.getResource("/test/test.map");
StringBuffer sb = new StringBuffer(mapURL.getFile());
sb.deleteCharAt(0);
mapObj map = new mapObj(sb.toString());
layerObj layer = map.getLayerByName("inline");
if (layer == null) return;
shapeObj shape = new
shapeObj(MS_SHAPE_TYPE.MS_SHAPE_POINT.swigValue());
lineObj line = new lineObj();
boolean error = false;
if (line.add(new pointObj(3500000, 5500000, 0)) ==
MS_RETURN_VALUE.MS_FAILURE.swigValue()) error = true;
if (shape.add(line) == MS_RETURN_VALUE.MS_FAILURE.swigValue())
error = true;
shape.setValue(0, "test1");
shape.setValue(1, "test2");
shape.setValue(2, "test3");
if (layer.addFeature(shape) ==
if (error) System.out.println("can't add point");
map.queryByRect(new rectObj(3400000, 5400000, 3600000, 5600000, 0));
int numRes = layer.getNumResults();
resultCacheObj infoResults = null;
if (layer.open() == MS_RETURN_VALUE.MS_FAILURE.swigValue())
System.out.println("can't open layer");
System.out.println("num res: " + numRes);
if (numRes > 0) {
infoResults = layer.getResults();
for (int resNr = 0; resNr < numRes; resNr++){
resultCacheMemberObj resObj = infoResults.getResult(resNr);
int shpIndex = resObj.getShapeindex();
System.out.println("shp " + resNr + ": " + shpIndex);
if (shpIndex >= 0) {
shapeObj tmpFeature = layer.getFeature(shpIndex, -1);
System.out.println("num values = " +
tmpFeature.getNumvalues());
test.map
MAP
EXTENT 3565000 5630000 3570000 5680000
IMAGECOLOR 255 255 255
IMAGETYPE png
SIZE 500 500
STATUS ON
UNITS METERS
NAME "MS"
OUTPUTFORMAT
NAME "PNG"
MIMETYPE "image/png"
DRIVER "GD/PNG"
EXTENSION "png"
IMAGEMODE "PC256"
TRANSPARENT FALSE
END
SYMBOL
NAME "circle"
TYPE ELLIPSE
POINTS
1 1
END
FILLED TRUE
END
PROJECTION
"init=epsg:31467"
END
QUERYMAP
COLOR 255 255 0
SIZE -1 -1
STATUS OFF
STYLE HILITE
END
WEB
IMAGEPATH "../temp/"
IMAGEURL "./mapserver/temp/"
END
LAYER
NAME "inline"
PROJECTION
"init=epsg:31467"
END
SIZEUNITS PIXELS
STATUS DEFAULT
TOLERANCEUNITS PIXELS
UNITS METERS
TYPE POINT
TEMPLATE "dummy"
CLASS
METADATA
END
STYLE
ANGLE 360
COLOR 255 0 0
SYMBOL "circle"
SIZE 10
END
END
END
END
