WMS projection error...
John Cole
john.cole at UAI.COM
Thu Mar 16 09:26:43 EST 2006
I think this would be a good note to put on the mapserver faq. Since I
found it by accident. I had set everything properly though the UI and never
saw the QGIS local entry. So it's possible to do everything right and still
have issues :-) Easy fix though, if you can find it.
John
-----Original Message-----
From: Frank Warmerdam [mailto:fwarmerdam at gmail.com] On Behalf Of Frank
Warmerdam
Sent: Thursday, March 16, 2006 8:23 AM
To: John Cole
Cc: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] WMS projection error...
John Cole wrote:
> Nikos,
> I had set a PROJ_LIB system environment variable already, but looking at
> it in the command prompt, I noticed it was set to the QGIS directory (not
> the ms4w directory I had set it). Sure enough, there was a local PROJ_LIB
> value that the QGIS install had set. I deleted that one but had to reboot
> (restarting IIS didn't work) to get mapserver to pick up the changes. Now
> it's working.
/me curses packagse that don't respect boundaries!
This is why FWTools takes this odd approach of installing all it's stuff
in one sub-tree, changing no external environment, and running in a self
contained fashion. Now, if all windows packages did the same we would
have no more DLL hell!
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | President OSGF, http://osgeo.org
