Double labels in Mapserver 4.8?
Giorgio Plazzotta plazzotta at TISCALINET.IT
Thu Mar 16 09:44:23 PST 2006
MAPSERVER-USERS Digest - 14 Mar 2006 to 15 Mar 2006 (#2006-75)I am sorry to insist on my request but I am still facing this problem of the double labels with the new Wamp + Cartoweb 3.2 environment and I need your help at least to see if you can replicate the problem. After having experienced the problem in one computer I tried with another having a different operating system (win xp instead of win 2000) and the problem is still there.
The new environment include windows, apache 2, php 5 mapserver 4.8 (php_mapscript), cartoweb 3.2 while the previous environment where the problem didn't show was based on Wamp5 1.4.5 (apache 1.3.x, php 5) + Cartoweb 3.1 (mapserver 4.6).
Would u please be so gentle to test the following:
on a winxp system or windows 2000 pro
- install wampserver 1.6.1 (wamp5_1.6.1.exe)
- install cartoweb 3.2 (cartoweb-setup-3.2.0b.exe) and (cartoweb-demo-setup-3.2.0b.exe)
- restart the wampserver
- open the demoCW3 project mapfile that should be located at C:\wamp\www\cartoweb3\projects\demoCW3\server_conf\demoCW3\demoCW3.map
- go to line 456 of the Mapfile and remove or comment the line with:BACKGROUNDCOLOR 245 235 235 (label section of the AGGLO layer)
- start the Cartoweb application ex: http://localhost select cartoweb3
- start the Cartoweb3 Demo application  in the main panel
- in the legend click on the go to scale Icon of the TOWNS layer in the Human activities block
- activate the TOWNS layer
- move to Wien (Vienna) or browse the map until u find any town with a name that include a blank
- check if u just see a normal label reporting Wien (Vienna) in 2 lines or if you see a doubles label reporting:
   WIEN
   WIEN
  (VIENNA)
  (VIENNA)
- pls tell me the result of your test
- in case you experience the same problems tell me if u have an idea of which element cause the double labels, considering that with winamp 1.4.5
and Cartoweb 3.1 this problem doesn't happen.
Thanx In advance
Giorgio
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060316/e400a588/attachment.htm>
More information about the MapServer-users mailing list
