MapServer, IIS and Oracle
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Fri May 5 03:39:44 EDT 2006
IIS only picks up new system environment variables after a reboot. Did
you reboot?
Best regards,
Bart
Léveillé wrote:
> Hi,
> I've been using MapServer (with Apache) with Oracle (10g) on Win XP.
> Everything use to work perfectly ...
> I'm now trying to make MapServer work on IIS, instead of Apache.
> I'm using the same computer, but Apache was removed.
> Here is what I did:
> - MS4W was downloaded and unzipped.
> - libmap.dll was downloaded and the original one was replaced (in
> ...\ms4w\Apache\cgi-bin).
> - 3 Env. vars were defined, as specified in (
> http://mapserver.gis.umn.edu/docs/howto/oracle_spatial_howto/view
> <http://mapserver.gis.umn.edu/docs/howto/oracle_spatial_howto/view>).
> - Full control was given (for now) to the internet user on the Oracle
> home directory.
> - getCapabilities looks OK (INPUT=ORACLESPATIAL)
> As I recall, I'm using the same computer, so the Oracle connection
> should be fine (it was working fine).
> But I get the following error when testing :
> *The WMS Server issued the following exception: msDrawMap(): Image
> handling error. Failed to draw layer named 'MyLayer'.
> msOracleSpatialLayerOpen(): OracleSpatial error. Cannot create OCI
> Handlers. Connection failure. Check the connection string. Error:
> ORA-12154: TNS: could not resolve service name.*
> Any solutions ??
> Thanks
> __________________________________________
> *James Léveillé*
> *Intélec Géomatique*
> 420, boul. Charest Est
> Bureau 400
> Québec (QC), Canada
> G1K 8M4
> Intélec Géomatique: 418.687.5000
> MTQ: 418.380.2005 (#227)
OSGIS, Open Source GIS
http://www.osgis.nl
