ms4w 1.5.2 - unable to get mapserv.exe or
php_mapscript_48.dll to work
Delfos, Jacob
Jacob.Delfos at MAUNSELL.COM
Mon May 8 01:22:56 EDT 2006
Hi Ben,
You have to be very careful with the DLL's. The error you get probably
means php_mapscript_48.dll is tryin to link to a DLL it is not
compatible with. Try to use the dependency walker
(www.dependencywalker.com) to find out which one it is (execute
"depends.exe php_mapscript_48.dll" in a command line window)
As I mentioned, the DLL's from MS4W are not compatible with those from
DMSolutions. Also, certain DLL's must be in the executable path in order
for them to work (just the system path may not be sufficient). For
example, gdal13.dll and the ER Mapper DLL's (and some others) probably
have to sit in the same directory as php-cgi.exe.
Regards,
Jacob
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Ben Madin
> Sent: 8 May 2006 13:17
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] ms4w 1.5.2 - unable to get
> mapserv.exe or php_mapscript_48.dll to work
> I have just downloaded the latest ms4w (1.5.2) and after
> installation
> (at c:\ms4w\) I get phpinfo() without trouble.
> However, when I click on mapserv.exe I get the following message in
> the error log :
> Premature end of script headers: mapserv.exe, referer : http://
> 10.0.1.2/index.phtml
> When I follow http://10.0.1.2/phpinfo_mapscript_48.php
> I get :
> Warning: dl() [function.dl.html]: Unable to load dynamic library '/
> ms4w/Apache/php/extensions/php_mapscript_48.dll' - The specified
> module could not be found. in C:\ms4w\Apache\htdocs
> \phpinfo_mapscript_48.php on line 2
> as the library is in this location, I assume that this is a problem
> related to Mapserver above.
> thank you.
> cheers
> Ben
> Ben Madin
> Remote Information Pty Ltd
> t/f: 08 9192 5535
> m: 0448 887 220
> ben at remoteinformation.com.au
