Premature end of script headers: mapserv
Juan Mari Celihueta
jmcm at EUSKALNET.NET
Wed May 10 04:41:49 EDT 2006
Hi Grabiel:
I don't think that is a file permission issue. All the permissions are
ok. The problem is that I cannot execute cgi-bin scripts from the
browser. Indeed, I have a 'test-cgi' script that shows the same error.
Moreover I have written a very simple cgi-bin test script and got the
same error. This scripts is simply:
#!/bin/sh
echo
echo "test"
Now I am checking the apache httpd.conf file for permissions to execute
cgi-bin scripts.
Thanks anyway, and tell me please if you have any other suggestion.
Regards,
Juan.
grabiel escribió:
> Hi
> Juan
> Check the file permission for mapserv and the path that preceeds it. If your mapserv is in /usr/local/apache/cgibin then
> set the file permission(write) for others etc. using chmod comand.
> If ur file permission is not set to write for each directory or mapserv then you may get the error that u have mentioned.
> Best of luck
> Grabiel
> Hi all,
> I have compiled successfully mapserver 4.8.3 under Solaris 8:
> $ ./mapserv -v
> MapServer version 4.8.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=PDF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER INPUT=TIFF
> INPUT=EPPL7 INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> However, when I put the mapserv file into the cgi-bin apache directory
> and try to open the file directly without any parameters from my
> browser, instead of the message expected ('No query information to
> decode. QUERY_STRING is set, but empty.'), I get an 'Internal Server
> Error' message. If I look the apache logfile I get this: 'Premature end
> of script headers: mapserv'.
> The LD_LIBRARY_PATH in the apache environment is:
> LD_LIBRARY_PATH=/usr/local/lib:/usr/local/ssl/lib
> export LD_LIBRARY_PATH
> Could anyone help me?
> Regards,
> Juan.
> No banners. No pop-ups. No kidding.
> Make My Way your home on the Web - http://www.myway.com
