OGR cut data after 510 characted?
Tamas Szekeres
szekerest at GMAIL.COM
Wed May 10 04:57:02 EDT 2006
http://bugzilla.remotesensing.org/show_bug.cgi?id=990
may be related to this problem.
Tamas
2006/5/10, Tero Alén <tealorama at gmail.com>:
> Hello everybody
> First little background. Our server is Linux server and we are using
> MapServer 4.8.1 (PHPMapscript). Our data is in MySQL database (MySQL
> because other part of our application use it). We use ODBC/OVF to get
> data from database.
> Problem is that query result give some unexpected result. If I make
> same query many times (using refresh) MapServer returns randomly two
> or three different results.
> When I used ogrinfo to test our ovf file I found that it will cut the
> geometry fields value after 510 character. The data is correct in
> database when I make query by hand. Yes, we are using MySQL's spatial
> extension and geometry column's type is geometry.
> ogrinfo also returns following error: ERROR 1: SetAttributeFilter()
> not supported on ExecuteSQL() results.
> Thanks for any help.
> -Tero
