OGR cut data after 510 characted?
Tero Alén
tealorama at GMAIL.COM
Wed May 10 10:33:10 EDT 2006
Thanks. I have to test if the patch fixes my problem.
-Tero
Tamas Szekeres kirjoitti 10.5.2006 kello 11.57:
> Hi,
> http://bugzilla.remotesensing.org/show_bug.cgi?id=990
> may be related to this problem.
> Tamas
> 2006/5/10, Tero Alén <tealorama at gmail.com>:
>> Hello everybody
>> First little background. Our server is Linux server and we are using
>> MapServer 4.8.1 (PHPMapscript). Our data is in MySQL database (MySQL
>> because other part of our application use it). We use ODBC/OVF to get
>> data from database.
>> Problem is that query result give some unexpected result. If I make
>> same query many times (using refresh) MapServer returns randomly two
>> or three different results.
>> When I used ogrinfo to test our ovf file I found that it will cut the
>> geometry fields value after 510 character. The data is correct in
>> database when I make query by hand. Yes, we are using MySQL's spatial
>> extension and geometry column's type is geometry.
>> ogrinfo also returns following error: ERROR 1: SetAttributeFilter()
>> not supported on ExecuteSQL() results.
>> Thanks for any help.
>> -Tero
