Premature end of script headers: mapserv
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Wed May 10 05:39:08 EDT 2006
What happens if you use PassEnv in the Apache httpd.conf to pass on the
LD_LIBRARY_PATH to the CGI? After that restart Apache ofcourse.
PassEnv LD_LIBRARY_PATH
Best regards,
Bart
> Hi Grabiel:
> I don't think that is a file permission issue. All the permissions are
> ok. The problem is that I cannot execute cgi-bin scripts from the
> browser. Indeed, I have a 'test-cgi' script that shows the same error.
> Moreover I have written a very simple cgi-bin test script and got the
> same error. This scripts is simply:
> #!/bin/sh
> echo
> echo "test"
> Now I am checking the apache httpd.conf file for permissions to execute
> cgi-bin scripts.
> Thanks anyway, and tell me please if you have any other suggestion.
> Regards,
> Juan.
> grabiel escribió:
>> Hi
>> Juan
>> Check the file permission for mapserv and the path that preceeds
>> it. If your mapserv is in /usr/local/apache/cgibin then
>> set the file permission(write) for others etc. using chmod comand.
>> If ur file permission is not set to write for each directory or mapserv
>> then you may get the error that u have mentioned.
>> Best of luck
>> Grabiel
>> Hi all,
>> I have compiled successfully mapserver 4.8.3 under Solaris 8:
>> $ ./mapserv -v
>> MapServer version 4.8.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>> OUTPUT=PDF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
>> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER INPUT=TIFF
>> INPUT=EPPL7 INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>> However, when I put the mapserv file into the cgi-bin apache directory
>> and try to open the file directly without any parameters from my
>> browser, instead of the message expected ('No query information to
>> decode. QUERY_STRING is set, but empty.'), I get an 'Internal Server
>> Error' message. If I look the apache logfile I get this: 'Premature end
>> of script headers: mapserv'.
>> The LD_LIBRARY_PATH in the apache environment is:
>> LD_LIBRARY_PATH=/usr/local/lib:/usr/local/ssl/lib
>> export LD_LIBRARY_PATH
>> Could anyone help me?
>> Regards,
>> Juan.
>> No banners. No pop-ups. No kidding.
>> Make My Way your home on the Web - http://www.myway.com
