Feature Selection/Get Info
rubydunes
rubydunes at YAHOO.COM
Wed May 17 13:00:29 EDT 2006
Thanks for the reply.
Here's the layer def for the Parcels shapefile:
LAYER
NAME Parcels
TYPE POLYGON
STATUS ON
DATA Parcels
TRANSPARENCY 45
TOLERANCE 3
TOLERANCEUNITS PIXELS
CLASSITEM OID
MAXSCALE 0
MINSCALE 0
SYMBOLSCALE 10000
LABELITEM 'PARCELID'
LABELMAXSCALE 20000
LABELMINSCALE 0
TRANSFORM TRUE
CLASS
EXPRESSION /./
TEMPLATE 'Parcels.html'
NAME Parcels
COLOR 197 217 151
OUTLINECOLOR 60 79 30
LABEL
FORCE TRUE
WRAP '@'
COLOR 0 0 0
SHADOWCOLOR 64 0 0
SHADOWSIZE 0 0
TYPE TRUETYPE
FONT courier
SIZE 4
ANTIALIAS TRUE
POSITION CC
PARTIALS FALSE
MINDISTANCE 1
BUFFER 1
END
END
END
In my template (Parcels.html) that gets launched after
the query for Parcels shapefile I just have a couple
of test fields. The file is simply:
[PARCELID]
[STREET]
Thanks for your time.
Bill
--- Steve Lime <Steve.Lime at DNR.STATE.MN.US> wrote:
> Hi Bill: Sounds like you're very close. Pasting in
> the layer def for parcels might help us diagnose
> some possible problems.
> The item tags are case sensitive and must match
> what's in the datasource exactly. For
> shaefiles that's typically all upper case but I have
> run into .dbf files with mixed case names.
> I'd check the actual names to make sure those match
> the tags you're using.
> Steve
> >>> rubydunes <rubydunes at YAHOO.COM> 5/16/2006
> 2:14:02 PM >>>
> Hey folks. I've tried everything and can't get a
> selection / get info tool to work. I set the MODE
> to
> QUERY and then click on a feature and it goes to the
> template for the layer as it should, but all I see
> are
> the field tags and not the information that should
> replace them.
> For example, if I click on a Parcel, the browser
> goes
> to Parcel.html (the template) but all I see is this:
> [PARCELID]
> [STREET]
> [NUMBER]
> etc...
> I must be missing an important step that sends these
> valuse to the template file. Right now it's like
> it's
> just opening the file.
> Any ideas? Thanks!!!
> Bill
> __________________________________________________
> Do You Yahoo!?
> Tired of spam? Yahoo! Mail has the best spam
> protection around
> http://mail.yahoo.com
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
