Limiting the viewable extent...
Steve Hall
steve.hall at MERCATORGEOSYSTEMS.CO.UK
Wed Nov 1 04:27:19 EST 2006
Thanks all for the suggestions, i'll have a look through and see what
works best for me.
I'm using MapScript so perhaps that may be the best way forward. The
multiple INCLUDEs is a nice thought too.
Cheers,
Steve H
Stephen Woodbridge wrote:
> Steve,
> I may be confusing this with a feature of ka-map, but I'm not sure.
> Steve L do you know if there is such a feature in mapserver?
> -Steve W
> ps: lots of Steve is confusing!
>>> Steve Hall wrote:
>>>> Hi all,
>>>> Is it possible to restrict the users viewable extent of the map
>>>> through the map file? For example, I have data loaded for the
>>>> whole of the country but I want it to be impossible for any client
>>>> tool to view data beyond a defined and fixed extent.
>>>> The EXTENT parameters just seem to set the initial extent and you
>>>> can easily zoom out beyond this extent.
>>>> I appreciate this is fairly easy to do through code but though that
>>>> if this was possible via a mapfile then it would be done at the
>>>> 'lowest' level...
>>> Yes, I believe you can do it by setting METADATA values for the MAP
>>> object. I just check the mapfile reference and it is not described
>>> there. Could you please write a documentation bug to request all
>>> METADATA controls be documented.
>>> -Steve W.
>> Thanks for this Steve, do you happen to know off hand any of the
>> relevant keywords to this problem (to get me started). I could take
>> a look through the code and dig deeper if I have somewhere to
>> start. This will also enable me to file a more accurate and useful
>> bug...
>> Cheers,
>> Steve H
Steve Hall
Technical Consultant
Mercator GeoSystems Ltd
Tel (UK) : +44 (0) 114 235 3409
Tel (US) : +1 (562) 735 3541
Fax : +44 (0) 114 235 3409
Mobile : +44 (0) 771 828 6323
Email : steve.hall at mercatorgeosystems.com
Web : www.mercatorgeosystems.com
Skype : mercatorgeosystems
