dbox imagepath, imageurl
william paul
williampaul28 at YAHOO.COM
Wed Nov 1 06:08:06 EST 2006
I think so. I don't know how to setup the rights. I used IIS to create an virtual directory and than I gave the write rights
What other setups should be made?
William
Barend Köbben <kobben at itc.nl> wrote:
Are you sure that the Mapserver process has access rights to write to the
temp dir? This was a problem initially in my setup...
__
Barend Köbben
International Institute for Geo-information
Sciences and Earth Observation (ITC)
PO Box 6, 7500AA Enschede (The Netherlands)
ph: +31 (0)53 4874253; fax: +31 (0)53 4874335
On 01-11-2006 08:04, "william paul" wrote:
> Hi:
> I am trying to use dBox. I managed to install it, but when I load the page I
> don't see the image. If I click on it I get the busy image. I think that the
> IMAGEPATH and IMAGEURL are not properly setup. I use IIS and Mapserver 4.6.0
> and I have everything in inetput/wwwroot. I have created and temp folder where
> I want to store the temporal images. I have setup in MAP file the imagepath
> and imageurl:
> IMAGEPATH "c:\inetpub\wwwroot\tmp"
> IMAGEURL "/tmp/"
> but nothing it is written there and no image is created. If I test on a new
> browser window the URL that is created when I load the main web page, then I
> get the image.
> Should I make other setups for dBox?
> Thank you
> William
> Everyone is raving about the all-new Yahoo! Mail.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061101/f13bedaa/attachment.html
