mapserv stdout png problem
Tamas Szekeres
szekerest at GMAIL.COM
Thu Nov 2 15:52:31 EST 2006
Hubert,
I've forgot that the TEMPLATEPATTERN should also be set in the mapfile like:
MAP
TEMPLATEPATTERN ""
END
I've also attached my template.html should be placed along with the mapfile.
If you would rather set the templatepattern with the query string like
..&map_templatepattern=&.. we could modify msLoadMapString accordingly.
Best Regards,
Tamas Szekeres
2006/11/2, Hubert Asamer <hubert.asamer at univie.ac.at>:
> Tamas,
> I've tried the following command:
> C:\Programme\FWTools1.0.6>mapserv
"QUERY_STRING=mode=browse&map=C:\ms4w\apps\maplab-2.2.1\tutorial\mymap2.map&
id=_&map_web_imagepath=images&map_web_template=template.html"
> But the result was a error message like this: mapserv(): Web application
> error. No template provided. <br>
> I think my template is not correct, or my query string is wrong
> (path....). Can you give me a more detailed description of how invoking
> the template (or please send your template) ?
> Thank you for your support,
> Hubert
> Tamas Szekeres wrote:
> > Hi,
> > AFAIK the only solution to workaround this issue is to create a
> > template and create the map image using this template. For example
> > create a template 'template.html' with
> > the following contents:
> > [img]
> > Then invoke mapserv with the query string against this template as for
> > example:
> > mapserv
"QUERY_STRING=mode=browse&map=MyMap.map&id=_&map_web_imagepath=samples\&map_
web_template=template.html&map_reference_status=off&map_scalebar_status=embe
d&map_legend_status=embed&mapsize=1000+1000"
> > Using the browse mode is required. The 'id' parameter will be appended
> > to your image name. The output image will be created relative to your
> > mapfile in the directory given to the 'map_web_imagepath' parameter.
> > Best Regards,
> > Tamas Szekeres
> > 2006/10/30, Hubert Asamer <hubert.asamer at univie.ac.at>:
> >> ---------- Továbított levél ----------
> >> From: Frank Warmerdam <warmerdam at pobox.com>
> >> To: Hubert Asamer <hubert.asamer at univie.ac.at>
> >> Date: Thu, 26 Oct 2006 15:55:24 -0400
> >> Subject: Re: mapserv stdout png problem
> >> Hubert Asamer wrote:
> >> > Frank,
> >> > one more question regarding the FW_Tools mapserv.exe:
> >> > When i make a query like this: mapserv
> >> "Query_string=map=.....&mode=map"
> >> > i get a png with following header: Content-type: image/png
> >> > Then i must remove the first two lines of the png file and i can
> >> view my
> >> > result-everthing ok!
> >> > Do you know how to configure my query to avoid these two header
lines?
> >> Hubert,
> >> There was some talk recently about adding a commandline switch to
> >> mapserv
> >> to supress this, but looking in the code it looks like nothing was
done.
> >> So, no, there is nothing that can be done.
> >> My msautotest test suite has special python code to strip off these
mime
> >> types, and the WxS mapscript wrappers include a mechanism to strip off
> >> the mime type. But I can't think of anything you can do when
> >> invoking mapserv
> >> at the commandline.
> >> Best regards,
> >> I set the clouds in motion - turn up | Frank Warmerdam,
> >> light and sound - activate the windows | http://pobox.com/~warmerdam
> >> and watch the world go round - Rush | President OSGeo,
> >> http://osgeo.org
> >> __________ NOD32 1.1831 (20061024) Information __________
> >> Diese E-Mail wurde vom NOD32 antivirus system geprüft
> >> http://www.nod32.com
No virus found in this outgoing message.
Checked by AVG Free Edition.
Version: 7.1.409 / Virus Database: 268.13.23/513 - Release Date: 2006.11.02.
